DUCATI
Re: DUCATI
ja und mit airbags, ski-sack, 80l tank, elektrischen fensterhebern und klima
- alfa_corso
Re: DUCATI
Technical Specifications
Type L-4 cylinder, liquid-cooled, DOHC, Desmodromic, 4 valves per cylinder, gear driven camshafts
Displacement 989 cc
Power 147,1 kW – 200 hp @ 13.800rpm
Torque 11,8 kgm – 85,55 lb-ft @ 10.500rpm
Fuel injection Four 50 mm Magneti Marelli throttle bodies, 12-hole “microjet” with injectors over throttle, manual idle control;
Exhaust 4-into-2-into-1 vertical exit exhaust/silencer
Emissions Euro 3
Transmission 6-speed; Cassette type
Clutch Dry multi-plate slipper clutch, hydraulically actuated
Vehicle
Body Full carbon fiber bodywork
Frame Tubular steel trellis hybrid, carbon fiber seat support, aluminum swingarm
Front Suspension Öhlins FG353P forks, 43 mm pressurized, with preload, rebound and compression adjustment, TiN coated sliders
Front Wheel Marchesini forged and machined magnesium alloy wheels, with 7 spoke design as GP6
Rear Suspension Öhlins rear shock, with rebound, low/high speed compression adjustment, and hydraulic preload adjustment
Rear Wheel Marchesini forged and machined magnesium alloy wheels, with 7 spoke design as GP6
Tyres Bridgestone, front 120/70 R17- rear 200/55 R16
Front Brake two Brembo radial “monoblock” calipers with four 34 mm pistons; two semi-floating 330 mm x 5 mm discs,
Rear Brake 240 mm fixed disc, caliper with two 34 mm pistons
Tank Aluminum alloy
Dry Weight 171 Kg / 377 lbs
Instruments New lightweight Corse electronic multifunction LCD dashboard with tachometer, speedometer, trip/odometer, trip fuel, clock, air temperature, engine temperature, lap time, anti-theft immobilizer, and several warning lights: fuel reserve, indicator lamps, oil pressure, neutral, high bean lamp, EOBD, overrev; complete error list.
Colors Two color versions: 1) Desmosedici RR: painted in ‘Rosso GP’, with a white number plate on the tail section; 2) the Desmosedici RR ‘Team Version’ - painted in ‘Rosso GP’, and as with the factory Corse bikes, with broad white stripe on the fairing.
Versions Single-seat
Re: DUCATI
geiles t-shirt.....
auf deutsch: schlecht erzogen!
vorne.....
vorne.....
- sessantanove
- Aktuelle Fahrzeuge: Audi S1
- alfaromeo65
- Aktuelle Fahrzeuge: Lancia Delta Integrale EVO, BMW X5
Ducati 999 Evoluzione
Darf es auch mal etwas auf 2 Rädern sein...?
Eben bin ich im Netz auf dieses wahrlich scharfe Teil gestoßen, als Basis dient eine handelsübliche Duc 999.
Nicht nur das die Leistung durch "Evoluzione Cyclesports" auf 165 PS angehoben wird, viel interessanter ist die Gewichtsreduzierung durch exessiven Einsatz von Carbon um 30 kg - auf sagenhafte 150 kg...
http://www.evoluzione.net/
Hier mal ein paar Fotos, unter den Bildern findet Ihr den Direct-Link für eine größere Auflösung:
http://dreambikesinc.com/EVO/Images/2.jpg
http://dreambikesinc.com/EVO/Images/3.jpg
http://dreambikesinc.com/EVO/Images/4.jpg
http://dreambikesinc.com/EVO/Images/6.jpg
http://dreambikesinc.com/EVO/Images/11.jpg
http://dreambikesinc.com/EVO/Images/5.jpg
http://dreambikesinc.com/EVO/Images/12.jpg
http://dreambikesinc.com/EVO/Images/7.jpg
http://dreambikesinc.com/EVO/Images/8.jpg
copyright by dreambikesinc.com
Viele Grüsse
Stefan
Walter Röhrl
Stefan
Walter Röhrl
- Antonello
Alfa GTV 6 Grand Prix
Alfa 155 T.Spark 16 V
Bmw 523
Vespa 50 Spezial
Ducati SS Carenata Von 1992- 1998
Hallo Leute ,
wie findet ihr die Ducati SS 750 / 900 Carenata von 1992- 1998?
Jemand von euch schon mal erfahrung gemacht mit diesem Bike?
LE Alfa le scelgono i piloti
Re: DUCATI
Durfte gestern wiedermal eine 900er i.E Monster Dark reiten...
... nicht gut, gar nicht gut!...
Alfetta GTV 2.0
Ducati Monster 900
Abarth 500 Competizione
Alfa 155 3.5 V6
Alfa 155 Q4
Alfa Giulietta QV
Alfa 33 16V QV - Wohnort: Nidwalden
Re: DUCATI
Doch, gut, sehr sehr gutDomi hat geschrieben:Durfte gestern wiedermal eine 900er i.E Monster Dark reiten...
... nicht gut, gar nicht gut!...![]()
- as
Re: DUCATI
Wo kriegt man diese Shirts?
