VORSICHT: Radarfallen!!!...
Informationen zu Autobahnen (Maut, Vigniette etc.) Engpässe (Gotthard, Mont Blanc etc.)
Baustellen etc.
Radar!
momo66
Beitrag von momo66 »
:D bin froh das ich helfen konnte^^
Zürich ende Hardbrücke (wo es anfängt Abwärts zu gehen, in richtung Albisriederplatz) wurde jetzt anscheinend auf 50 beschränkt und ein neuer Kasten aufgestellt!
Kann das jemand bestätigen?
momo66
wie?
meinst du richtung hebräer kuartier?
wen ja dan ja aber den kasten konnte ich ned sehn da bauarbeiten da waren!
nein ich meine, wie es oben steht ende Hardbrücke (Beim Hardplatz!)
mo155
Beitrag von mo155 »
SCHEISSE.
STEALTH RADAR SYSTEM SEES THROUGH TREES, WALLS -- UNDETECTED
COLUMBUS, Ohio -- Ohio State University engineers have invented a radar system that is virtually undetectable, because its signal resembles random noise.
The radar could have applications in law enforcement, the military, and disaster rescue.
Eric K. Walton, senior research scientist in Ohio State's ElectroScience Laboratory, said that with further development the technology could even be used for medical imaging.
He explained why using random noise makes the radar system invisible.
"Almost all radio receivers in the world are designed to eliminate random noise, so that they can clearly receive the signal they're looking for," Walton said. "Radio receivers could search for this radar signal and they wouldn't find it. It also won't interfere with TV, radio, or other communication signals."
The radar scatters a very low-intensity signal across a wide range of frequencies, so a TV or radio tuned to any one frequency would interpret the radar signal as a very weak form of static.
"It doesn't interfere because it has a bandwidth that is thousands of times broader than the signals it might otherwise interfere with," Walton said.
The radar can be tuned to penetrate solid walls -- just like the waves that transmit radio and TV signals -- so the military could spot enemy soldiers inside a building without the radar signal being detected, Walton said. Traffic police could measure vehicle speed without setting off drivers' radar detectors.
Like traditional radar, the "noise" radar detects objects by bouncing a radio signal off them and detecting the rebound. The hardware isn't expensive, either; altogether, the components cost less than $100.
The difference is that the noise radar generates a signal that resembles random noise, and a computer calculates very small differences in the return signal. The calculations happen billions of times every second, and the pattern of the signal changes constantly. A receiver couldn't detect the signal unless it knew exactly what random pattern to look for.
The radar can be tuned to penetrate solid walls -- just like the waves that transmit radio and TV signals -- so the military could spot enemy soldiers inside a building without the radar signal being detected, Walton said. Traffic police could measure vehicle speed without setting off drivers' radar detectors. Autonomous vehicles could tell whether a bush conceals a more dangerous obstacle, like a tree stump or a gulley.
The radar is inherently able to distinguish between many types of targets because of its ultra-wide-band characteristics. "Unfortunately, there are thousands of everyday objects that look like humans on radar -- even chairs and filing cabinets," he said. So the shape of a radar image alone can't be used to identify a human. "What tends to give a human away is that he moves. He breathes, his heart beats, his body makes unintended motions."
These tiny motions could be used to locate disaster survivors who were pinned under rubble. Other radar systems can't do that, because they are too far-sighted -- they can't see people who are buried only a few yards away. Walton said that the noise radar is inherently able to see objects that are nearby.
"It can see things that are only a couple of inches away with as much clarity as it can see things on the surface of Mars," he added.
That means that with further development, the radar might image tumors, blood clots, and foreign objects in the body. It could even measure bone density. As with all forms of medical imaging, studies would first have to determine the radar's effect on the body.
The university is expected to license the patented radar system.
Contact: Eric K. Walton, (614) 292-5051; Walton.1@osu.edu
Written by Pam Frost Gorder, (614) 292-9475; Gorder.1@osu.edu
http://researchnews.osu.edu/archive/noiserad.htm
kurz zusammengefasst: es wurde ein neuer radar entwickelt, er kann durch büsche, bäume, wände usw. durchgehen und kann so sehr gut versteckt werden. alsob das noch nicht genug wäre, kann man ihn nichtmal per detektor entdecken, da er irgendwelche umgebungsgeräusche zufällig generiert und damit misst.
hab den artikel nur kurz überflogen. aber scheisse ists trotzdem.
didiklement
Beitrag von didiklement »
jango155 hat geschrieben:SCHEISSE.
Bis das auf den Markt kommt (so in 8 Jahren) werden Autos sowieso Fahrtenschreiber haben, dann nützen Radaranlagen gar nichts mehr.
Florian
Gruppo Radicale
Beitrag von Florian »
in Basel gibts zwei neue... einer nach dem Schwarzwaldtunnel richtung BE/ZH und einer von der Verzweigung Wiesenknoten richtung Eglisee Qaurtier.
ähmm habe ich Euch schon erzählt? Chrigi hats schon wieder geblitzt und zwar wieder mit dem 164er von Vitor. Das ist jetzt etwa das fünfte mal in vier Monaten. :roll: :twisted: :(
PS: Das der Mann nur so stark gebüsst wurde wie wenn er vorwärts gefahren wäre finde ich blöd. Schliesslich ist es doch viel Gefährlicher wenn einer Rückwärts auf der Vorwärtsspur mit diesem Tempo noch entgegen fährt. Das ist ja im Prinzip das gleiche wie Geisterfahrer. Aber so dämmlich scheint das Gesetzt zu sein. Da kann ich mich ja auf was freuen :roll:
_________________
sash
Beitrag von sash »
FRAGE:
weiss jemand obs in den neu erbauten Tunnels zwischen Urdorf und Birmensdorf intsallierte Radaranlagen gibt?
Henry Ford
Tiramisu
Beitrag von Tiramisu »
@sash
JA es gibt sie, versteckt hinter einer überholverbotstafel für lastwagen!!!
sash
Beitrag von sash »
@ Tiramisu
Danke.. sind nämlich schöne neue Tunnels die jetzt um Zürich gebaut werden.. :twisted: :lol:
Henry Ford
Ein neues Blitzdings steht in Zürich Bucheggstrassse Stadteinwärts zwischen den beiden Tunnels! Wehntalerstrasse - Bucheggplatz! :evil:
wurde der Laserkasten bei der Einfahrt Winti-Töss richtung Zürich eigentlich entfernt? als ich das letzte mal durchfuhr, war die spur gesperrt und die arbeiter demontierten das ding gerade.. :twisted:
jag_rip hat geschrieben:wurde der Laserkasten bei der Einfahrt Winti-Töss richtung Zürich eigentlich entfernt? als ich das letzte mal durchfuhr, war die spur gesperrt und die arbeiter demontierten das ding gerade.. :twisted:
Also letzte Woche war die Spur noch gesperrt und der Kasten demontiert... ich schätze mal bis die arbeiten dort erledigt sind...
Domi hat geschrieben:
sind immernoch am worken (ist zwar kein mensch am arbeiten)
:roll:
Gast
Beitrag von Gast »
Chrigi hat geschrieben:naja mit lärm hat das ja nichts zu tun... ich kann auch im 1. am Drehzahbegrenzer dort vorbei kesseln
UND ICH NUR MIT STANDGAS :lol: :twisted:
